Recording Temperatures at a node or location
Old   January 14, 2007, 03:09
Default Recording Temperatures at a node or location
venigall
Is it possible to record the temperatures at a particular node or location as a function of time during an unsteady simulation?
Thank You Venigall
Old   January 14, 2007, 06:50
Default Re: Recording Temperatures at a node or location
Rajesh
Yes ..its possible.. Creat point from "surface>point"..If you know the x,y coordinates of the point where you need the temperature history, give the coordinates..or you can display the grid and creat the point with the mouse. Then go to "solver>monitors>surface"....give a particular window number for your plot in that check "plot/print/write" with "Every>timestep" ...go to next page by "define"... "Report of>temperature" "Surfaces>"select name of your point "Report type>vertex average/facet average"...(read manual!) "X axis> Flow time" "Plot window> number of the window you have givem in the first page File name> name of your temperature history file...
that's all!
Hope thus helps
Rajesh
Old   January 15, 2007, 05:05
venigall
Thanks rajesh.
it worked perfectly and i have selected facet maximum.
venigall
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
License server not visible from master node Charles FLUENT 0 October 30, 2007 17:48
how can i list node temperatur by node location Ali Doustdar FLUENT 2 July 12, 2007 23:48
How to find & view location of a node in CFX? Bill CFX 2 December 6, 2005 13:18
