Floating point error
Old   January 16, 2007, 10:17
Default Floating point error
Nabil
When Fluent ranning on my machine and I want to display any grid or countours or some think it comimg on getting a floating point error in Fluent. I get the following error.
Error: Floating point error: divide by ziro Error Object: ()
I get this only on my Dell PC (P4 Dimesion 8400)what are the key areas to cross check when we face such error messages. Can anyone explain. Thanks
Old   January 16, 2007, 12:12
Default Re: Floating point error
Ralf Schmidt
Hi!
PLEASE!! look at the forum BEFORE you are asking. Or performe a seach!!!
SO MANY PEOPLE are looking for the floating point error (one just a few days befor), and to all of them I write the same:
look at
http://www.cfd-online.com/Wiki/Fluen..._I_avoid_it.3F
Ralf
Old   January 19, 2007, 05:30
Akshay
If you have successfully run your case file and you are getting error only during display of grid,(not only for this, for all different cases too) then it is problem with your graphics card.
Please use the following commands when you launch fluent from command prompt. fluent [version] -driver x11 for unix. fluent [version] -driver msw for windows.
You may have to upgrade your graphics card driver. It should be available on the site of your graphics card vendor.
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
Problem with UDF compiling for kTkLW model Wantami FLUENT 0 July 18, 2011 05:11
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
