heat transfer
Old   January 25, 2007, 00:53
Default heat transfer
madhan
hi.. friends.. i want to find the thermal distribution over the 2D rectangular metal plate using fluent 6.1.18 with a moving heat source in the horizontal direction on the plate.. it s similar like welding operation.. can you suggest some methods and procedures to model the problem...
Old   January 25, 2007, 14:19
Default Re: heat transfer
Sujith
You can model the source term as position dependent and time dependent. use DEFINE_SOURCE() macro;
suppose your source is moving linearly along x coordiante, t = 0, S(x=0)= 1; t = 1 , S(x=1) =1;....
/*Inside the UDF you can get the cell centroid, and flow time*/ C_CENTROID(x,c,t); t = CURRENT_TIME; /*check the x coordinate with time */ if (x[0] = t) S =1;
cell centriod may not be xactly = to time, you may check within a range;
Hope its clear
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Convective / Conductive Heat Transfer in Hypersonic flows enigma Main CFD Forum 2 November 1, 2009 22:53
How can I increase Heat Transfer at Domain Interf? B.Simon CFX 3 October 28, 2008 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
