Unable to set home environment in gambit
Old   January 17, 2007, 02:37
Default Unable to set home environment in gambit
Neel Naik
I get an error message appears every time I try to start up gambit. A dos-window appears which states that a "Home environment must be set" and the window closes. "set environment" from FluentInc menu does not help. Is there anything I can do manually? Does "Exceed" have anything to do with this? Should I install exceed first and then Gambit?
Old   January 18, 2007, 20:22
Default Re: Unable to set home environment in gambit
Ken Adams
As far as I know, "Exceed" is required for running Gambit. If you want, you could download an evaluation copy of "Exceed" from http://connectivity.hummingbird.com. Hope it helps.
Old   January 19, 2007, 08:17
Akshay
Hi, I hope you have done this step start->all programs->fluent[version] on right site you would find set Environment option. click and seee if the ntx86 to which it is pointing is at the same location and same folder.
Old   January 23, 2007, 11:02
Nissan master
I got the same problem and fixed it this way:
Open the CONTROL PANNEL and click SYSTEM and select ADVANCED Click on ENVIRONMENT VARIABLES Click NEW and write
variable name: HOME variable value: c:\flexlm (this is a folder you MUST have)
Click OK and create another NEW variable:
variable name: GAMBIT_ROOT variable value: C:\Program Files\Exceed.nt\gambit2.0\ (or the path which leads to the folder where Gambit is installed)
This worked for me and hope it will work for you.
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
cannot start gambit "set environment error" frank FLUENT 18 November 14, 2009 14:31
home environment john FLUENT 2 May 24, 2004 05:55
unable to open gambit uma FLUENT 2 July 2, 2003 11:56
Home environment must be set!! Michael Vredevoort FLUENT 1 April 1, 2002 13:59
