cycle average temp
Old   January 25, 2007, 02:46
Default cycle average temp
kamini
hi
I am doing cfd analysis of a pulse tube refriegaror. In this project their is cylinder piston arangement and other parts are their. the piston vecocity is given by
V=.09 COS(213t)
their is a change in temp in different part as simulation going on.
how to got the graph between cyle average temp ~ time ? not static ~time
please reply
ammi
Old   January 29, 2007, 13:52
Default Re: cycle average temp
Seeker Phil
Hi Ammi, This is not striaght forward to accomplish using Fluent alone. The way I would recommend working around this is to use surface monitors. Define a monitor at the surface where you would like the average temperature. (Solve--> Surface Monitors). Then go on to define the Y-axis as "Flow time"
Doing the above will record your time varying data into a monitor file. At the end of your simulation you can use Matlab, Excel or techplot to plot your results!
Good luck, Phil
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
Average Facet, Surface Vertex or Area-Weighted Emmanuel FLUENT 3 March 27, 2020 10:55
Udf function average temp inlet - outlet erodv FLUENT 4 October 6, 2017 11:16
Passing Average Temp from Outlet to Inlet Steve Scotts FLUENT 1 August 27, 2008 05:02
how to find cycle average temp ammi FLUENT 0 January 22, 2007 03:01
