March 11, 2007, 23:48 |
Add a layer of cells, dynamic mesh or ...?
Hello everyone,
Does anyone know how it would be possible to add a layer of cells to our original geometry during the solving process in fluent. The geometry is simple (2D-strctured mesh). I have a transient problem which needs to add a row of cells to one aspect of original solution during the solving. Thanks, Modisa |
March 12, 2007, 02:01 |
BOUNDRY CONDITION PROBLEM
hi
i am modeling a pipe flow .helium is flowing through pipe. outside the pipe is water circulate to remove the heat from helium .so heat transer occur from helium to water . i am doing on 2d problem.WALL THICKNESS IS TAKEN AS ZERO . By default it is takes air as outide fluid . how can it be done water is outside the pipe. |
[snappyHexMesh] snappyHexMesh not refining surfaces | Hydro1004 | OpenFOAM Meshing & Mesh Conversion | 3 | August 29, 2012 11:56 |
[snappyHexMesh] Boundary layer in a pipe | Clementhuon | OpenFOAM Meshing & Mesh Conversion | 6 | March 12, 2012 12:41 |
[snappyHexMesh] SnappyHexMeshDict | fabrizio | OpenFOAM Meshing & Mesh Conversion | 25 | October 14, 2011 07:00 |
[snappyHexMesh] Tweaked motorbike tutorial doesn't show my icosphere | mfiandor | OpenFOAM Meshing & Mesh Conversion | 0 | October 9, 2011 18:39 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
