Boundary Conditions in Gambit for a dam break model
Old   October 2, 2009, 09:48
Default Boundary Conditions in Gambit for a dam break model
Lindsey
Lindsey is on a distinguished road
I created a mesh for a 3D dam break model. I plan on doing a VOF model with LES. I have two volumes; water and air. I am unsure of what to name the side where the vertical dam is ( the front of the water volume). Also the end of the flume is a free fall, what is the boundary condition for a free fall? I have decided to name the top of the water surface that meets the air volume as interface, should this be something different? Thank you for your time
Lindsey
Lindsey is offline   Reply With Quote
Old   October 5, 2009, 01:51
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Regarding VOF, just set 2 separated fluid domains in Gambit (icon next to BC)
You don't need to set any fluid interface
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 5, 2009, 02:53
Philipov's Avatar
Svetlin Filipov
Philipov is on a distinguished road
Ensure you patch the water domain before calculation...
Philipov is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Boundary Conditions - air-blast atomizer model Sofia FLUENT 0 April 7, 2007 05:02
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 07:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
