March 20, 2013, 17:44 |
Granular Temperature Model : Material
Rep Power: 14 |
Can someone please help me with defining the viscosity of the new material that I create in Granular Temperature Model. I don't know the viscosity of the material, I just have the density. What value should I input in that case in the viscosity? Thanks. |
January 31, 2017, 14:17 |
Granular phase material property
Nimmy
Rep Power: 9 |
Fluent manual mentions that the only property of the granular phase that has to be specified is the density. It further says one can ''ignore'' the rest of the property values, not mentioning if we can use 0 as the input for these properties. Anyways I have experience of a crashing simulation when ''0'' was specified for the viscosity of the granular phase. So, I suggest a random value to be entered in this field. It must be understood that the viscosity (solid shear viscosity+ frictional viscosity) for granular phase is calculated through the user-chosen closure functions Fluent provides, if not user-defined functions . For ex. Lun et.al for bulk viscosity and so on.
please find the links to Fluent documentation for further details. P.S: Even though it's a late reply, hope a newbie is helped through this and not waste precious computational resources doing trial and error to clarify this (like me)!! https://www.sharcnet.ca/Software/Flu...ug/node947.htm https://www.sharcnet.ca/Software/Flu...cosity-syamlal |
Problems with CEL (guess it's simple to solve) | Felggv | CFX | 22 | March 26, 2019 16:42 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 00:58 |
Granular model with 2d axisymmetric | K.Fukumoto | FLUENT | 2 | September 15, 2013 11:15 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
