DPM residuals for sampler
Old   April 10, 2007, 11:56
Default DPM residuals for sampler
Don Parsons
First of all thank you all for your help. I have asked so many questions and as of yet have not fealt confident enough to give any advice.
Now for my new questions if you all will be som kind as to offer a little more help. I am simulating a cyclone sampler. I have allowed the continuous phase to converge to e-6 (we are still in the preliminary stages). The flow is assumed to be steady state for now. I then set the DPM for steady state particle tracks. I have enabled interaction with the continuous phase and said update source terms every iteration. I am doing 1 DPM iteration per 40 continuous phase iterations. Also I am doing a surface injection.
My first question is does the above procedure seem reasonable? My second question is how do I know when the particle tracks are converged? Once I start my iterations with the DPM on the residuals jump up and oscilate about 7e-4 with amplitude of about half an order of magnitude. Will these residuals ever come down or does the converged solution have oscilating residuals.
Thanks for the help in advance.
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 171 February 20, 2024 02:55
what to monitor besides residuals? franzdrs FLUENT 5 March 21, 2013 03:59
DPM modeling Mohsin FLUENT 0 March 31, 2010 22:11
Oscillation of residuals in DPM (Ergent need!) yooceframandi FLUENT 1 February 28, 2006 06:46
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
