grid independence
Old   April 26, 2007, 17:55
Default grid independence
dibya
how to know grid independence in any problem , is it necessry to find out
Old   April 27, 2007, 04:50
Default Re: grid independence
gopal
it is not necessary to find out grid independence, but for supplying the time step size or the courant number, and for some turbulence parameters, knowledge of the grid dependence is necessary.
Old   April 27, 2007, 09:16
myron
If you want to know how well you are capturing the physics - then grid independence is a definite must. (If you double the mesh count - and your answer changes by more than a few percent - then you know your original mesh was probably not causing any flow characteristics. If the answer changes by more than that - then you know the mesh itself was influencing the flow results.)
grid independence questions lucifer FLUENT 0 December 14, 2009 19:59
unstructured mesh grid independence for Fluent Shane Schouten FLUENT 0 October 11, 2006 16:50
Grid independence check Mattis Voss FLUENT 1 November 23, 2005 10:30
Grid Independence problem for simple pipe geometry chanchala FLUENT 13 November 20, 2003 08:24
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 05:59
