peroidic boundary condition
Old   April 13, 2007, 11:42
Default peroidic boundary condition
Ramesh.K
hi all,
i am trying to simulate flow around a compressor blade, i wanted to use peroidic boundary condition to the surfaces but this particualar bc is not availabe in the menu of bc's when i use fluent. my question is do we need to specify any thing while we model the geometry and mesh the geometry for such cases. i have used icem cfd to mesh the volume around the blade. and i have done hexa hedral mesh for this particular volume.
i request to tell me how to model, mesh and use peroidic boundary condition using fluent.
thanking u all
Ramesh.K
Old   April 13, 2007, 22:44
Default Re: peroidic boundary condition
sam
You can make periodic boundary using the fluent text command interface. or you should specify in Gambit.
did u make the Hexa or Tetra mesh, Which type of compressor you are modeling.
Regards
Old   April 14, 2007, 06:22
Ramesh.K
hi sam, i have made hexa mesh using icem cfd. its an axial flow compressor. can u explain how to create with text command interface.
bye ramesh
Old   April 17, 2007, 10:41
Rahul
Dear Ramesh,
I suggest you to make a geometry in GAMBIT (you can export your existing ICM geom to Gambit). In gambit you have to first "link" the edge/face meshes of the periodic boundary. In the zone specification, assign the edge/face to periodic boundry. this will give you the desired boundary condition of periodic once you export the mesh to Fluent.
Old   April 25, 2007, 06:28
sam
No need to make geometry in Gambit. Just use the text command interface. it is easy just check out help of fluent.
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Can anyone give me some hint on how to make traction free boundary condition? poplar OpenFOAM 3 January 14, 2015 02:37
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
