radiation DTRM vs. S2S comparison
Old   February 12, 2017, 07:54
Default radiation DTRM vs. S2S comparison
saimen
saimen is on a distinguished road
Dear CFD community,
I am simulating radiation heat transfer between two concentric cylinders filled with air and came up with the following problem:
When I simulate heat transfer between the cylinders using S2S radiation I get different results as when I use DTRM with absorption coefficient 0. In my opinion these two models should deliver the same results...
In my case we can assume an optical thin medium, therefore S2S radiation would fit well for the problem. I am a bit confused because DTRM more or less should do the same as S2S radiation for absorption coefficient 0.
Does anyone have an explanation?
Regards
saimen
saimen is offline   Reply With Quote
Old   February 14, 2017, 03:34
saimen
Hello all
I found the solution. Fluent does not like to have absorption coefficients that are 0. When i use e.g. 10e-5, then the DTRM shows similar behaviour as S2S.
Regards
saimen
dtrm, fluent, heat transfer, radiation, s2s
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 10:29
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation volleyHC CFX 5 April 3, 2016 05:41
Radiation Modeling Chris89 CFX 20 August 14, 2014 07:51
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
S2S radiation model sagila FLUENT 3 April 23, 2014 06:05
