3D plots in fluent
Old   May 11, 2007, 05:50
Default 3D plots in fluent
bharat
hi fnds, can anybdy help me to plot 3D graph of variables in fluent thank you
Bharat Makwana
Old   May 11, 2007, 08:37
Default Re: 3D plots in fluent
Adriano
fluent can't plot 3D graphs; you can extract data by exporting them and plot them in excell or in Matlab (better). A
Old   May 11, 2007, 13:06
A A S
Why is Matlab better?
Old   May 14, 2007, 04:58
Dr. Flow Squad
It just is!
Old   May 15, 2007, 12:47
A A S
Excel is quick and dirty. I like it!
Old   May 17, 2007, 11:33
Ketan
how can we extract data from fluent. Actually I want to plot axial distantce V/s Radial velocity (is dimensional less)i.e radial velocity/ (r*w), where r = radial coordinate & w = rotational velocity of refernce frame, These at different times that are also dimensinal less t/Ts t = actual flow time and Ts = sqrt(w)/sqrt(E) E = ekman number.
Old   May 24, 2007, 12:17
Adriano
If your case is time dependent, save frequently (by outsave) and run a macro that save in a ascii file the variables that you need. After import them in matlab and good luck
If you have just performed the calculation, write a matlab cod that write a fluent journal file such as:
read-case xx-1.cas read-data xx-1.dat //file/export/ascii pathFile\nomeFile-1.YYY nomeSurfaceOrInterior () yes listOfVariables
read-case xx-2.cas read-data xx-2.dat //file/export/ascii pathFile\nomeFile-2.YYY nomeSurf () yes listOfVariables
read case xx-N.cas read data xx-N.dat //file/export/ascii pathFile\nomeFile-N.YYY nomeSurf () yes listOfVariables
hope it's helpful
good luck
A
Old   May 24, 2007, 13:32
bashu
There is a matlab code that reads all the data is acsii in one big file and you can use it to plot the data. I don't think you can do a 3D plot with 2 varaibles.
Here is where you can get it:
http://www.iit.edu/~mostmoh/visual.html
Old   May 25, 2007, 12:22
Ketan
hi
I din't understand what u told me. i dont know how to write code in matlab. can u please explain in detail or do they have any documentaion regarding this. Thanks Ketan
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
