What boundary conditions should I apply?
Old   April 15, 2020, 06:54
Default What boundary conditions should I apply?
ocyee is on a distinguished road
Hello guys, would like to observe the droplet internal flow, velocity contour and streamline when the base of the water droplet is applied with a vibrating condition, a simple example would be a sine function. However, I could not figure out the boundary conditions for the FLUENT setup. Since there is no inflow or outflow from the droplet, what boundary conditions should I be applying to the droplet?
ocyee is offline   Reply With Quote
Old   April 15, 2020, 07:23
Default Clarity
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Are you talking about a single droplet? If it is so, and there is no inlet and outlet, then the free-surface of the droplet behaves like a wall; a wall with some velocity and shear stress. The vibration will impose exactly that. However, if there are vibrations normal to the surface of the droplet, then you have to apply source terms adjacent to the outer surface because wall cannot have a normal force applied. Other option is to model it using free surface model, i.e., VOF and then you can apply any kind of force at the free-surface.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 15, 2020, 07:47
Yes. My idea is to observe droplet dynamics on a glass slide. But for simplicity, I want to just ignore the glass slide for now, and just focus on the droplet instead. Therefore, the vibrating condition underneath the droplet base itself, normal to the base of the droplet. Regarding the VOF model, i am currently using that in FLUENT, but isnt that just a setting that we just toggle it on and off in the application before calculation?
Old   April 15, 2020, 08:01
Just to be clear, regarding the boundary conditions, do I just set the water droplet base as wall and apply a UDF velocity, and the water droplet-air interface as wall with no slip boundary conditon? Thanks in advance!
Old   April 15, 2020, 08:02
Default Vof
vinerm's Avatar
Vinerm
Volume of Fluid model is not just a setting. It's a model that allows to solve for two things - volume fraction of the secondary phase, such as, liquid droplet in the gas, and determination of the interface. Now, due to the vibrations, the interface shape and size might change. So, VOF will be able to predict that. If you assume that the shape and the size of the droplets do not change much and your interest lies solely in the prediction of flow within the droplet, then you do not require VOF and can work with single phase model.
Regards,
Vinerm
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Can NOT apply the boundary conditions for T-Rex Connor Sun Pointwise & Gridgen 0 March 12, 2019 05:12
Velocity vector in impeller passage ngoc_tran_bao CFX 24 May 3, 2016 21:16
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
