Phase Change ....!!
Old   May 15, 2007, 05:52
Default Phase Change ....!!
prakash
Dear CFD Users
I am solving Phase change problem, but I don't know how proceed this, please give me some suggestions. My Problem as follows
... Liquid Nitgogen filled in an open (top side) tank and the other tank walls are insulated. The liquid nitrogen gets vaporated due to atmosphere temperature. Here liquid nitrogen is partial filled in the tank.
I want to know how solve this problem in FLUENT Please give me some suggestions
Your suugestions are appreciable Thanks in advance
regards
Old   May 15, 2007, 10:48
Default Re: Phase Change ....!!
Frackowiak
I worked with Fluent to model evaporation at the interface of a sphere. The interface is considered as a boundary, I set a first arbitrary flow rate. Temperature and vapor mass fraction were set in agreement with Clapeyron law, through a boundary conditions profile, provided by an external program in Fortran. Computation of the flow gave me the species gradient, from which I deduced a new mass flow rate according to species conservation at the interface. (in an other external problem too) And I did 2 or 3 iterations until I got same flow rate as boundary counditions and deduced from flow calculation.
Concerning your problem, if interface remain fix, you can split liquid and gas phase, interface is therfore a boundary coundition for each one. And write a program which ensure equilibrium at the interface, dealing with exported or imported boundary profiles.
Bruno
Old   May 15, 2007, 20:12
prakash
Thank you Mr.Bruno, I hope I understand your explanation. But I am not good enough in FLUENT. Could you give me any related tutorial in FLUENT and UDF to approach this problem
Thank you once againg for your good explanation
prakash
Solid/liquid phase change fabian_roesler OpenFOAM 10 December 24, 2012 06:37
About phase change heat and mass transfer Michael FLUENT 2 February 13, 2011 01:49
Phase change phdsantos FLUENT 0 March 20, 2009 10:19
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 03:59
How to model the solid-fluid phase change in CFX ohrmond CFX 2 May 26, 2006 06:27
