parallel processor
Old   May 25, 2007, 04:08
Default parallel processor
ritmat
I am trying to resolve my model with a computer with processors in parallel. My geometry is a boiler so that is not an easy geometry but not totally tricky as well. I am trying first to use only 2 processors in parallel and i got this error message: ////////////////////////// iter continuity x-velocity y-velocity z-velocity energy k epsilon do-intensi time/iter unable to read the cmd header on the pmi context, generic socket failure, error stack: MPIDU_Sock_wait(2533): The specified network name is no longer available. (errno 64).
999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory unable to read the cmd header on the pmi context, generic socket failure, error stack: MPIDU_Sock_wait(2533): The specified network name is no longer available. (errno 64).
job aborted: rank: node: exit code[: error message] 0: fluent.int-aet.dk: 123 1: fluent.int-aet.dk: -1073741819: process 1 exited without calling finalize The Parallel FLUENT process could not be started. ///////////////////////////
I was thinking first that i could not have a partition trough the porous zone of my heat exchanger but even without crossing the heat exchanger zone it doesnt work. I am using a metis partition ( i tried as well with others ) which seems the best in my case but without positive results. I would be pleased if you can help me Thank you
Old   May 25, 2007, 05:57
Default Re: parallel processor
Thomas
Try to read the msh with the 1core version. Set the case. Then read it in parallel. Let us know.
Old   May 25, 2007, 06:15
ritmat
i already did, in parallel with one processor it is working
Old   May 29, 2007, 06:26
ritmat
it is actually working with autopartition. I dont really know why cos the metis partition looks better. If anyone has an idea , thank you
Old   November 13, 2011, 06:00
Emre G
emreg is on a distinguished road
Originally Posted by ritmat
;141905
is it really a valid solution?
is there anyone had experiences such that problem?
emreg is offline   Reply With Quote
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Parallel LES computation stops with reason vvqf OpenFOAM Running, Solving & CFD 4 March 6, 2006 07:55
