Create a high quality movie from multiple files
Old   June 13, 2007, 09:38
Default Create a high quality movie from multiple files
Dr. Flow Squad
This Guide should help you to create high quality CFD animations. Feel free to check it out
http://tinyurl.com/3ablhk
The title is "Create a movie from a list of images"
- Dr. Flow Squad
Old   June 13, 2007, 11:35
Default Re: Create a high quality movie from multiple file
Brice
That looks like a sweet tutorial! Quick question: if the pictures are generated while Fluent is iterating, how are they accurate? isn't the solution only accurate once the residuals have converged engough? Brice
Old   June 13, 2007, 17:35
bashu
Brice, this is normally done for an unsteady case where the model is converged at each time step and you want to look at the evolution of the parameter with time (filing a tank). also can be used if you want to have animation of a steady case but rotate the view or zoom in or out or ...
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Animation of multiple cgns files John Smith Main CFD Forum 0 February 19, 2008 14:57
Autocad high quality STL file Autocad to CFD guillaume Main CFD Forum 1 July 31, 2007 05:48
Transient solution multiple CGNS files in Tecplot Ramses Galaz Tecplot 3 October 17, 2006 10:43
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
