refine mesh!!
Old   June 2, 2007, 10:08
Default refine mesh!!
Donia
hi, how can i refine mesh with Fluent not Gambit? thanks
Old   June 2, 2007, 10:51
Default Re: refine mesh!!
S.
You can refine a mesh by selecting the Adapt menu and choosing how you want to the adaption to be performed. For instance, if you select say Adapt->Gradient you can refine the mesh based on gradients of many properties. You would first select the property i.e. velocity->X-Velocity then click on "compute" (this gives you the maximum gradient value). You would enter a refinement threshold less than the computed maximum and click "Mark". This will show you how many cells/nodes are going to be added. If you are happy with everything then click "Adapt". A message will appear mentioning a "hanging node" just click "OK". You can then go to display grid and view the added cells. Hope this helps!
S.
Old   June 2, 2007, 17:13
donia
thanks a lot!!
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Netgen] How to refine mesh? skovhus OpenFOAM Meshing & Mesh Conversion 0 February 23, 2010 12:30
How to refine O-grid hexa mesh? Pete Main CFD Forum 2 November 15, 2004 06:40
