[Sponsors] | |||||
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
how could i resolve this problem, please help me. |
hi when did u recive that?
you should describe more. I think it's a common error message you can get all the time.
it happened when user defined sources were added in the fluent.
Please check whether you have correct thread as a parameter when modifying your domain with source term
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
| How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
| Dynamic Mesh UDF | Qureshi | FLUENT | 1 | December 2, 2009 00:27 |
| UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
| UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
