multiphase models
Old   June 11, 2007, 18:20
Default multiphase models
AK
I am trying to simulate a boat issuing exhaust underwater. The exhaust pipes issue a mixture of water and exhaust gases into the water body (lake). The lighter gaseous part rises to the surface behind the boat. The immiscible gases exit the water domain and air flowing around the boat disperse them. I am required to capture the concentrations of these gases.
I know I can use the VOF model to capture the air-water interface. Separately, I can use the mixture model to capture the dispersion of gases in water. But I need to be able to do both things at the same time!! I need some help in trying to figure out if it is possible, or if alternate solution strategies are possible.
Thank you, AK
Multiphase Models !! please help me. kpcamber FLUENT 0 September 26, 2011 12:27
how to use MIXSIM to simulate multiphase models weiz FLUENT 1 November 26, 2009 00:40
How to give volume fraction in multiphase models chhanwal FLUENT 0 August 13, 2009 00:07
granular multiphase models lurk FLUENT 4 January 23, 2008 04:51
Multiphase models Nima Sheyad FLUENT 7 November 4, 2002 08:20
