June 18, 2007, 23:20 |
can we know y plus in icem or gambit?
Hi I wanted to know that, can we know y plus in advance (during grid generation)? Thanks
June 19, 2007, 04:08 |
Re: can we know y plus in icem or gambit?
NO. As y+ is function of parameters like the friction velocity (u*) which is dependent on the velocity you generally input in the solver part. The y+ value is not constant and will change with whatever boundary condition (velocity) you input in your solver and also varies with location.
June 19, 2007, 04:20 |
you can calculate the y+ using the parameter u will be inputing in the solver, once u know the y+ value, make mesh such that the first node lies within this y+.
check out FLUENT documentation for y+ calculation |
[ICEM] Gambit to Openfoam, Gambit to ICEM to Openfoam | Rickard.Solsjo | ANSYS Meshing & Geometry | 7 | November 30, 2011 10:20 |
Gambit extracting & ICEM | hashem_1064 | ANSYS Meshing & Geometry | 2 | October 22, 2009 02:19 |
Help: mesh conversion from Gambit to ICEM | sarah_ron2002 | FLUENT | 2 | April 5, 2008 01:53 |
How to export gambit model to ICEM | Nirupama | Main CFD Forum | 1 | October 28, 2006 13:06 |
Gambit or ICEM CFD | Alan | FLUENT | 7 | January 10, 2006 09:03 |
