Problems with User Defined Scalar
Old   June 26, 2007, 14:55
Default Problems with User Defined Scalar
Alberto Cuoci
I am trying to solve an additional transport equation using 1 UDS. When I use the non-premixed combustion model (flamelets), FLUENT does not modify the diffusion coefficient for the additional UDS. When I change the corresponding value in the Materials Panel there is no effect on the simulation; the value remains 1 kg/m/s, which is the default value. I also tried to define an external UDF ( DEFINE_DIFFUSIVITY(name, c, t, i) ) to change the default value, but the result is the same.
Do you have any suggestions?
Thanks, Alberto
UDF to modify the value of a user defined scalar Raja Banerjee Fluent UDF and Scheme Programming 5 March 5, 2019 14:19
dieselFoam problem!! trying to introduce a new heat transfer model vivek070176 OpenFOAM Programming & Development 10 December 23, 2014 23:48
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 12:21
solving passive scalar by user function in AVLFIRE huyp Main CFD Forum 0 September 4, 2008 10:21
How to store my own information to a USER SCALAR? LI Ying CFX 1 August 15, 2001 16:55
