Help required on porous medium
Old   June 26, 2007, 03:28
Default Help required on porous medium
aero
I am working on CFD analysis using porous material in the model. I am new to set up this type of BC'S.
Can you help me in stting alpha & beta values.
If you have any material or link which gives details on setting up such Analysis, Please forward it.
regards aero
Old   June 27, 2007, 12:46
Default Re: Help required on porous medium
Pavs
The alpha & beta values are basically to model the inertial and viscous resistance to the flow due to the porous medium. There are pure and semi-empirical relations to model these parameters. Most of these are explained in Section 7.19.6 of the user guide in the Fluent documentation. For the specific case of laminar flow, terms described by the Blake-Kozeny relations (Eqs 7.19-17 & 7.19-18) are rather good. Maybe you should read through that section and see if it's useful to you. Hope this was helpful.
Good luck.
Pavs
Flow through porous medium using CFX: lack of convergence Chander CFX 3 July 23, 2014 06:32
Lack of local thermal equilibrium in porous medium Chander CFX 4 March 4, 2012 04:07
Modelling sound propagation through layered porous media nkinar Main CFD Forum 0 July 4, 2010 14:45
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
porous medium and reactions Valeria FLUENT 1 July 10, 2009 03:58
