UDF to monitor force
Old   July 13, 2007, 15:25
Default UDF to monitor force
Emmanuel
This is a basic question about FLUENT, how can I monitor the force value that I obtain from REPORT-->FORCES-->WALL. I tried SOLVE-->MONITORS-->FORCE-->WALL, but this monitors the drag coefficient. Do you have any suggestions? If a UDF is needed, can you give me a sample UDF.
Old   July 16, 2007, 07:58
Default Re: UDF to monitor force
Giles
If you set the reference values in report--> reference values so that F=0.5*density *area* velocity^2*CD then the two methods will give the same thing. Hence setting density to 2, area to 1 and velocity to 1 will do exactly this. This will not affect the solution values only the way the coefficient if calculated.
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
