computing combusion with the segregated method |
July 23, 2007, 23:49 |
Hello, Does anyone have experience of comuting combustion with the segregate method? I'm now computing the combustion a liquid droplet. But the coupled method can't be used together with VOF model. Ideal gas is used in the simulation, so the pressure should be strongly coupled with the density. This will cause serious problem of convergency. Could anyone give me some suggestion? I used dual time stepping method. Will it help to improve the convergency?
Thank you, Jin |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
Help about the preconditioner in gmres method | Dan Gao | Main CFD Forum | 3 | July 5, 2008 01:18 |
Convergence Definition of Segregated Solver | Amir | FLUENT | 0 | April 18, 2006 06:21 |
Why Segregated method is still being used? | Sam | Main CFD Forum | 40 | July 25, 2005 03:07 |
