Multiple Fluid Zones
Old   August 3, 2007, 05:29
Default Multiple Fluid Zones
Naghman Khan
I am trying to model a rotating body. I was following Fluent tutorial 8 on Multiple Rotating Frames which uses multiple fluid zones.
However there is no corresponding Gambit tutorial which identifies how to do this.
I am trying to get my rotor (consisting of 15 blades on a vertical axis) to rotate. However in Gambit it won't allow me to define a fluid zone around the blades I keep getting error messages saying that: Continuum or Boundary conditions specified for faces x and y are not valid for Fluent 6.
Can anyone help please? Thanks
Old   August 3, 2007, 06:27
Default Re: Multiple Fluid Zones
olivier
Have you define a zone of fluid in gambit? You must define different zone in Gambit Continuum condition faces. If you do that and it don't work y can't help you.
Old   August 3, 2007, 06:35
Naghman Khan
Olivier, thanks for your reply.
I have 15 blades which have 6 faces each defined as walls. Then I have tried to encompass these is another cylindrical volume which I have defined as a fluid zone in the continuum types.
Is this the correct procedure?
Thanks again
Old   August 3, 2007, 07:23
olivier
I think it is correct. But if it doesn't work I don't know what you can do.
Good luck for your model.
boundary condition between porous and fluid zones Mansureh FLUENT 5 June 5, 2011 09:31
How to use / How to find IPMT? camoesas CFX 2 November 23, 2010 06:36
Fluid Dynamics Eng - PAX Mixer - San Rafael, CA Gary Jong FLUENT 0 February 25, 2008 20:46
My Revised "Time Vs Energy" Article For Review Abhi Main CFD Forum 2 July 9, 2002 09:08
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
