importing from Solid Works
Old   August 27, 2007, 09:32
Default importing from Solid Works
andrew hayes
I am having trouble importing my solid works file. I have been successful doing this with older versions of Gambit, but v2.4 keeps telling me either a) 0 faces, 0 edges, 0 vertex have been imported or b)translation requires license feature geom-trans. Is it possible that the university's license file doesn't allow Solid Works importing? I have tried ACIS, Parasolid, IGES, Step files with no luck. Any suggestions would be appreciated.
thanks
Old   August 27, 2007, 10:03
Default Re: importing from Solid Works
Pedro ROS
Hi, I have been using STEP files successfully, generated on my PC by the solidworks 2005 available on emule...
Old   August 28, 2007, 13:22
andrew hayes
do you have to declare the flow volume in Solid Works? I can import the 3d drawing, but I can't seem to define the flow volume.
Have you tried using the solid works ad-on made by Fluent? I am having trouble with that as well.
thanks
Old   August 28, 2007, 13:58
Pedro ROS
I just imported the geometry on a step file into gambit. to continue with the meshing process there. Unfortunately I did not use anything else. Sorry.
Basic advice on Importing Solid Edge model to CFX needed. stephen__white CFX 1 February 9, 2011 18:40
Importing from Solid Works mettler FLUENT 1 March 5, 2005 23:45
Get Free Geometry File -Solid Works Joe Brian Main CFD Forum 0 December 16, 2004 23:25
Importing of Solid files in PROSTAR or PROAM jafar Siemens 1 November 26, 2001 09:20
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
