Which Turb. Model is Suitable for Re=140000?
Old   September 8, 2007, 05:04
Default Which Turb. Model is Suitable for Re=140000?
Mahbub
Dear
I am trying to simulate the flow over cylinder at Re=140000. I tried by some turbulent model, but didn't get good result. I tried to find Cd and the vortex shedding. Could any one please tell me, which model is suitable in this case ? Thanking all of you.
Mahbub
Old   September 9, 2007, 04:17
Default Re: Which Turb. Model is Suitable for Re=140000?
Jesse
SST
Old   September 9, 2007, 07:58
Mahbub
Dear Jesse
Thank you for your co-operation. I have used K-omega SST turbulent model but I didn't get the vortex shedding and my Cd=0.112 (that is far from experimental value). I use: u=1, mu=1, D=1, densiry=140000 to get Re=140000 also put k=0.00138, w=0.11, time step size=0.014.
Would you please give me any sugession?
Mahbub
Old   September 11, 2007, 20:34
Sham
I think with such high Re, your time step size is large. Try setting your time step size so that you Courant number is less than 1 as I was told. Also amke sure your grid is fine enough at the critical region.
Old   September 12, 2007, 08:13
Mahbub
Dear Sham
I used Time step size = 0.01, and the courant number = 0.7, isn't enough? I still confused to set Re number. When I change density to change Re then I get the result, but if I copy Water-liquid from fluent data base and change velocity to change the Re then I didn't get the result. I think Razvan can give me any suggestion. Could you please gibe me the mail address of Razvan?
Thanking you,
Mahbub
Atomization and Breakup model xck1986 OpenFOAM 4 May 31, 2014 04:43
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Kato-Launder model sam Main CFD Forum 13 September 21, 2006 10:15
Algebraic turb. model emre FLUENT 4 June 4, 2003 10:04
What is low-Re-number for Near wall model in turb yueroo FLUENT 1 February 28, 2001 15:39
