regine adapt problem
Old   September 12, 2007, 23:18
Default regine adapt problem
wanghognb
hi,all,
my model is a cylinder,there are 18440 cells. the z-axis range(0,0.005m).when z-axis range is (0,0.005m)in my region adaption,computer tell me:18440 cells marked for refinement,when z-axis range is(0,0.0025m),there are 18427 cells marked for refinement. WHY are not 9220 of the cells marked for refinement?
Old   September 13, 2007, 19:55
Default Re: regine adapt problem
AAA
what is your criteria for adaption in your case?
Are you trying to adapt based on the gradient of a variable?
Old   August 30, 2010, 10:46
Default adapt region criteria
Rafael
ranaca is on a distinguished road
Hi! When I do a grid adaption using the adapt--> region option, I bound a region of the domain I want to adapt, but, which criteria is applied to adapt the grid?? I mean, will it be devided in a certain number of cells, or is the pressure, velocity, temperature... the parameter taken into account??'
Thanks!!!
ranaca is offline   Reply With Quote
Problem with interFoam; Wave/wiggle alpha1 behavior JonW OpenFOAM 10 February 4, 2023 07:27
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
