dynamic mesh bondary layer cells
Old   October 12, 2007, 17:42
Default dynamic mesh bondary layer cells
geri
Dear experts,
I am trying to analize the rigid body moving capabilities in fluent in case of bridge deck section flutter assassement. I applie a boundary layer mesh and I want this region move with the rigid body and not to deform or change. Can it be achieved???
Thanks
Old   October 13, 2007, 21:41
Default Re: dynamic mesh bondary layer cells
Giles
Make the spring constant in the DM smoothing settings 0, so the movement is spread as globally as possible. In addition if possible make the UDF move the deforming surface 10% of what you need it to move, then perform 10 mesh updates with it, so each step is small. This worked for me, hope it works for you.
Old   October 14, 2007, 07:26
geri
Dear Giles!
Thanks for Your answer, the zero value of the spring factor solves the problem, the boundary cells move beautifully with the rigid body. I just don't understand what You mean the 10%!!! (My UDF is the simples as it can be, it defines a prescribed motion of a body).
Many thanks,
Geri
Old   October 16, 2007, 07:16
Amr
Hi, If you have already a simple UDF (compiled ofcourse), then you can assign the UDF to both the body as well as the boundary layer. This would give the exact prescribed motion to the cernters of gravity of both.
To do so, you may want to have a look on the 6DOF UDF made on the fluent users website (need to have an access) and make use of the "calls" and "Num_Calls" variables. This is just for calling the function twice before writing the new locations on centers of gravity, thus enabling motion for both of your Blayer and the body itself.
If you find this difficult, you can still live with the low spring constant afterall.
Amr
Old   October 16, 2007, 09:47
Geri
Dear Amr,
This solution seems to be the best, i will try it.
Many thanks
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 09:13
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
dynamic mesh + boundary layer cells Geri FLUENT 0 November 1, 2007 16:27
