November 8, 2007, 10:29 |
S2S radiation model
Dear all,
I want to use S2S radiation model for my simulation. But I recive an error while computing the view factors. The error is: "FATAL ERROR: Cannot open parameter file D:\Coupling Provide full path to I/O file D:\Coupling command to execute: "C:\Fluent.Inc\utility\viewfac2.1\ntx86\vfs216.exe " D:\Coupling Validation\2d-solid\2d-solid.s2s.gz Reading "| gunzip -c \"D:\Coupling Validation\2d-solid\2d-solid.s2s.gz\""... You must read in a view factors file or disable S2S model before proceeding. Error: Failed while reading view factor file. Error Object: () Error: Error reading "| gunzip -c \"D:\Coupling Validation\2d-solid\2d-solid.s2s.gz\"". Error Object: #f " Some information about my model: My model comprises of solid and fluid domain. So I have a coupled simulation between solid and fluid. Is this the source of error? Thanks alot in advance for your advice. |
December 8, 2007, 14:36 |
Re: S2S radiation model
Hi, Remove any spaces in the path where you are writing the viewfactor file. Eg. My Documents etc.. Basically, save it in a different path without the spaces.
anderson |
How model radiation of both solid wall and fluid£¿ | Harry Qiu | FLUENT | 2 | February 3, 2013 23:04 |
how to write and read view factor file in radiation model S2S | chhanwal | FLUENT | 1 | March 25, 2009 10:54 |
radiation model | brian | FLUENT | 0 | July 27, 2007 10:57 |
RE: Radiation model | Ashutosh Joshi | FLUENT | 1 | January 30, 2001 10:50 |
