Suppressing messages
Old   December 14, 2007, 09:32
Default Suppressing messages
Ola Dahlin
Is there any way of suppressing the messages Fluent delivers during iteration?
For instance if I have pressure-inlet or outlet I don't want to see the 'reversed flow' message in EVERY iteration flooding my screen.
- Ola
Old   December 14, 2007, 09:45
Default Re: Suppressing messages
sastry
same problem i also phased with my project
after i cleared this problem
what ever the fluent giving "reversed flow" during iteration is correct, it is operating in its operating condition given by you
i did a compressor proublem,so many days i got this reversed flow i didnt get the result what i want, then finally i came to know that i operated the compressor in surge condition (reverse flow only will come in surging of compressor),then i made it in normal condition.
can u clearly explain about your proublem?
Old   December 14, 2007, 09:53
Ola Dahlin
I think you misunderstood the issue here! I'm not worried about the reversed flow, if it's correct or why there is a reversed flow. I just want to suppress the message so that it doesn't APPEAR on my screen while iterating.
- Ola
Old   December 14, 2007, 10:27
k.baker
You can let the message not appear in your window by the GUI just go to solve menu then select set then flow-warnings and press enter then you will see the following message: enable flow warning messages? [yes]
hence if you not want see the messages choose NO and fluent will not display it again.
with complements k.baker
Strange messages at the end of CFX .out file Albi CFX 2 April 17, 2007 02:17
Assembler messages when compiling on AMD64 hani OpenFOAM 4 May 22, 2006 08:08
Warning messages usker Siemens 0 April 8, 2006 22:47
Some Forum Messages Lost Jonas Larsson Main CFD Forum 1 August 31, 2005 23:53
error messages Nurul Murad FLUENT 1 September 3, 2001 00:38
