flow path lines
Old   December 13, 2007, 06:08
Default flow path lines
JSM
Dear all,
In post processing,
Display ->path lines-> pulse
to see the flow paths clearly in the domain. There is any way to capture this as animation file (avi or mpeg).
Simulation is steady state.
with warm regards, JSM
Old   December 14, 2007, 09:27
Default Re: flow path lines
sastry
yes there is a way to capture the movie file , but it require lot of memory(RAM)and harddisk space and lot of time
To get the the small file(1 min) need to wait more than two hours,
to get this movie file
The option has to give before starting the iteration from the stable state(accepted error free solution) of the solver,
this is like the way that we are observing the residuals,during the iterations,
solve-->animate--->define--->select what u want
then u start iterations
due to this per itaration time will increase
try it
Old   January 10, 2008, 17:05
Peter Herman
Possibly a much easier/quicker option - Download and purchase the very inexpensive ($40) little utility called "Hypercam" and just "snatch" an avi file right off the screen as it runs "realtime". I use this method for all my Fluent animation captures - even the ones where Fluent's "animation" capabilities are used to generate the motion. You do have to experiment a bit with the frame capture rate (if you want small avi file size), though, to get something that isn't "jerky" (depends upon the frame update speed that Fluent is generating).
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
Flow path control manual edit in autogrid njiang Fidelity CFD 0 June 22, 2011 18:03
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
