how to connect an edge with a face
Old   January 15, 2008, 17:49
Default how to connect an edge with a face
Usman
hi, how can i connect an edge with a face in Gambit. The edge is just over the face.
Many Thanks,
Old   January 16, 2008, 05:53
Default Re: how to connect an edge with a face
sushii
Things are not clear! could you explain a little more of your problem..?
Old   January 16, 2008, 08:19
Usman
hi, actually i have three cross-sections of a turbine blade (at hub, midspan and tip). I am trying to make blade out of it. i have made the hub and casing. I want to connect hub and casing cross-sections of blades to hub and tip respectively. Unfortunately, i don't have Gturbo software. I am making geometry in Gambit. Many thanks for your help dear friend.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
