pressure udf
Prev Previous Post   Next Post Next
Old   May 19, 2022, 05:19
Post pressure udf
cedric k
le-ceko is on a distinguished road
Hi all,
I work on a project and i'm pretty new in UDF.
I have to set an udf depending on the mass flow rate at the outlet.
i try to write an udf code but it doesn,t work :
#include "udf.h"
DEFINE_PROFILE(pressure_outlet,t,i)
real inlet_mass_flow_rate = 0.025 ; /* liquid inlet mass flow rate */
real current_mass_flow_rate; /* declare variable for the current mass flow rate */
real error;
real kp = 50; /* proportional constant */
face_t f;
begin_f_loop(f,t)
current_mass_flow_rate = F_FLUX(f,t); /* F_FLUX is the mass flow rate through a face */
error = inlet_mass_flow_rate - current_mass_flow_rate; /* difference between each mass flow rate */
F_PROFILE(f,t,i) = F_P(f,t) + kp * error; /* pressure definition */
end_f_loop(f,t)
I think i have forgotten something. I found an article about that so they said that :
the set point of the exit mass flow rates ( sp
mexit ) was determined as the inlet mass flow rate. The error (Ei)
between the set point and the actual mass flow rate ( ie
m xit ) at the ith time level was calculated as follows:
Ei = msp -mexit
The exit pressure ( i+1 Pexit ) at the next time level was obtained from the current exit pressure (P i exit ) and a correction value proportional to the error
Pexit(i+1) = P(i) - K Ei
le-ceko is offline   Reply With Quote
UDF for vapor pressure anuarun Fluent UDF and Scheme Programming 12 December 24, 2021 10:12
UDF to adjust pressure outlet a.lynchy FLUENT 4 February 15, 2021 00:50
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 13:04
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 16:29
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
