May 19, 2022, 05:19 |
pressure udf
cedric k
Rep Power: 4 |
I work on a project and i'm pretty new in UDF. I have to set an udf depending on the mass flow rate at the outlet. i try to write an udf code but it doesn,t work : #include "udf.h" DEFINE_PROFILE(pressure_outlet,t,i) { real inlet_mass_flow_rate = 0.025 ; /* liquid inlet mass flow rate */ real current_mass_flow_rate; /* declare variable for the current mass flow rate */ real error; real kp = 50; /* proportional constant */ face_t f; begin_f_loop(f,t) { current_mass_flow_rate = F_FLUX(f,t); /* F_FLUX is the mass flow rate through a face */ error = inlet_mass_flow_rate - current_mass_flow_rate; /* difference between each mass flow rate */ F_PROFILE(f,t,i) = F_P(f,t) + kp * error; /* pressure definition */ } end_f_loop(f,t) } I think i have forgotten something. I found an article about that so they said that : the set point of the exit mass flow rates ( sp mexit ) was determined as the inlet mass flow rate. The error (Ei) between the set point and the actual mass flow rate ( ie m xit ) at the ith time level was calculated as follows: Ei = msp -mexit The exit pressure ( i+1 Pexit ) at the next time level was obtained from the current exit pressure (P i exit ) and a correction value proportional to the error Pexit(i+1) = P(i) - K Ei |
UDF for vapor pressure | anuarun | Fluent UDF and Scheme Programming | 12 | December 24, 2021 10:12 |
UDF to adjust pressure outlet | a.lynchy | FLUENT | 4 | February 15, 2021 00:50 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 13:04 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
