Values of k and omega at the wall
Old   February 19, 2008, 10:52
Default Values of k and omega at the wall
oldah
I'm running a k-omega model on a pure natural convection flow around a horizontal cylinder. The flow is in the turbulent regime and as such a transition over the cylinder is expected. I've found that the roughness height controls where the transition point is and without any roughness there is no transition.
I have looked at the wall boundary value for omega in the manual, which includes the roughness height, but I can't find how the value of k is calculated and if the roughness height is included in these equations? Could someone refer me to these equations?
The reason that I'm so interested in how the roughness is used in the solution equations is that the k-omega model is the only model in Fluent 6.3 and Fluent 12 which will produce a solution which exhibits transitions phenomena.
best regards - Ola
Old   February 20, 2008, 02:50
Default Re: Values of k and omega at the wall
Ralf Schmidt
hi!
as i know, k is zero at the wall. It is difined from the turbulent fluctuations of the velocity - and these are allways zero az the wall!
Hope, it helps Ralf
Old   February 22, 2008, 03:08
oldah
Indeed the velocities at the wall are zero but the TKE is non-zero at the wall, how can this be? There must be something I'm doing wrong when plotting and displaying contours over the TKE, no?
I'm using k-omega on a horizontal cylinder, y+ = 1.6.
k-omega-SST model (OF 1.6) - turbulent flat plate cboss OpenFOAM Running, Solving & CFD 25 August 9, 2016 09:53
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
low reynolds k omega / wall functions stawrogin OpenFOAM 1 March 30, 2011 06:04
Omega at the wall sla FLUENT 0 January 10, 2011 04:16
Wall function implementation K Omega SSt cbarry OpenFOAM 3 August 18, 2009 10:09
