Fluent Post Processing
Old   February 18, 2008, 02:54
Default Fluent Post Processing
Kulasekharan N
Hi... I am studying a case of flow past cylinder. Cylinder is placed perpendicular to the stream direction inside a rectangular duct. (Re - based on pin dia, vmax < Re,critical). Turbulent, Incompressible, steady, 3d, air flow).
Question: Whether it is possible to plot any property (say., Static pressure distribution) on the developed surface of pin circumferential face. ie., if the pin surface is developed, i will get a rectangular sheet. On that i would like to plot the static pressure distribution of the pin.
Thanks in advance.
Kulasekharan PhD Scholar, IIT Madras
Ansys Post Processing Brian_P Main CFD Forum 0 March 4, 2010 16:05
Surface Post Processing Graham Main CFD Forum 0 November 11, 2009 14:49
Post processing in FLUENT praveen.jpk FLUENT 1 September 10, 2009 01:58
Different in fluent result after post processing Niles FLUENT 0 August 14, 2008 04:28
post processing in CFD MANISH BHARGAVA Main CFD Forum 0 October 17, 1998 20:51
