Problems with the UDF in Fluent
Old   February 26, 2008, 16:24
Default Problems with the UDF in Fluent
Mathew
I am making the manual of fluent "Modeling uniform fluidization in 2D fluidized bed" and in that udf uses one, the compiler is used, the windows is in define/User-Defined/Funtion/Compiled
The file c is called bp_drag, soon I give click him build and leaves this in the console
************************************************** ** Make sure that UDF source files are in the directory that contains your case and data files. If you have an existing libudf directory, please remove this directory to ensure that the latest files are used. 1 file copy. (system "move user_nt.udf libudf\ntx86\2d")0 (system "copy C:\Fluent.Inc\fluent6.1.22src\makefile_nt.udf libudf\ntx86\2d\makefile") 1 file copy (chdir "libudf")() (chdir "ntx86\2d")()
Done ************************************************** ***
now when I give click to the button load is when it leaves the error leaves this in this console
////////////////////////////////////////////////////// Opening library "libudf"... Error: open_udf_library: El sistema no puede hallar el archivo especificado.
Error Object: ()[/b] //////////////////////////////////////////////////////
The File c, I put it where this the case archives, but continues failing somebody can say to me because it leaves error, the version of the fluente is the 6.1
Old   February 26, 2008, 19:15
Default Re: Problems with the UDF in Fluent
lurk
if you're doing the tutorial of the fluidized bed then you can use the interpret function in fluent instead of the external compiler. If you have to use the compiler function then you probably do not compile the UDF correct. I had also problems with that in the beginning, but the answer is at the fluent home page on the FAQ: compiling UDF. -lurk
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 13, 2017 23:23
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
UDF for Viscoelastic Fow in Fluent skris2009 FLUENT 2 September 19, 2011 23:59
udf fluent 6.3.26 don't work in fluent 12 enry Fluent UDF and Scheme Programming 16 September 9, 2010 02:44
Problems on Compiling UDF in FLUENT Strawberi-KeatKeat FLUENT 1 October 4, 2006 01:50
