Answer Yes or No.
Old   February 29, 2008, 10:31
Default Answer Yes or No.
Shim
Hei,
FLUENT can plot the Drag force as belows In case of circular cylinder.
1. Monitor--Forces..
2. Refort--> Forcse..
3. UDF
4. Surface Integrals using Costoms Flied Funtions where pressure difference on the surface of circular cylinder. Drag force = pressure force + viscous force pressure force = intergral (static pressure - pressure coefficent) at circular surface. viscous force = Wall Fluxes--> X-wall shear Stress
5. Moment difference between inlet and oulet.
Force = sum(Velocity inlet*density*Projected area*Vin)
- sum(Velocity inlet*density*Projected area*Vout)
Am i right??? YES or NO.
Thank you very much for your answer.
And. One more, If cylinder wall is not wall. it mean is porous-jump... How can get the Force on the surface of porous cylinder.
Best regards Shim.
ACRi ANSWER analogs dmishe Main CFD Forum 0 May 17, 2011 05:19
To red lemon pls answer K.Baker FLUENT 0 August 2, 2007 09:41
I have caculte the answer is 'Yes'.What do you thi Hsu M. Main CFD Forum 28 June 27, 2006 16:33
Appreciate for your any answer Klawu FLUENT 2 January 20, 2005 06:01
Has anyone heard of ANSWER code? J. Garroni Main CFD Forum 0 September 15, 1999 09:10
