March 7, 2008, 13:16 |
Unsteady run in Fluent
Hi, That is my 1st simulation in Fluent. I dont know how to specify the steady solutions as the initial conditions for an unsteady run?
--Thanks, selim |
March 8, 2008, 08:15 |
Re: Unsteady run in Fluent
If you have specified a Velocity-inlet boundary condition it would be good to use it ('Compute from' drop-down list in the Solve-Initialize... menu) for initializing the domain.
But generaly- initializing depends on the BC you've set. |
March 11, 2008, 03:02 |
it is simple,
As first step run your solution as steady state. secondly change your solution type to unsteady state and solve it. fluent will automatically take your steady state results as initial condition for your unsteady case. beware, never to intilize your solution when to solve unsteady case because it will over write your steady state results |
using UDF in Fluent for unsteady cavitation | Pejman | Main CFD Forum | 6 | November 6, 2008 10:18 |
Postprocess of Fluent for unsteady problem | Rana | FLUENT | 5 | August 21, 2006 04:30 |
Unsteady flow in FLUENT | Vidya Raja | FLUENT | 2 | November 2, 2005 16:29 |
Unsteady Flow in FLUENT | Vidya Raja | FLUENT | 0 | November 1, 2005 17:54 |
unsteady calcs in FLUENT | Sanjay Padhiar | Main CFD Forum | 1 | March 31, 1999 12:32 |
