March 13, 2008, 11:33 |
Fluent & Ubuntu 7.1
Has anybody out there had any luck running Fluent 6.3 under 64-bit Ubuntu 7.1? There seems to be some incompatibility. I have had good success with Fedora Core 4 and 6, but there are various good reasons (such as all hardware being supported) why I would like to keep this particular computer on Ubuntu.
March 13, 2008, 20:43 |
Re: Fluent & Ubuntu 7.1
I've tried without any success, but if you manage to get it up and running please either post your method here or e-mail me at wgh112@psu.edu . I have very similar concerns with regard to hardware.
March 14, 2008, 02:45 |
No, you cannot run Fluent on any other linux systems except Red Hat, Fedora, and Suse. Fluent is not designed for that.
March 14, 2008, 05:45 |
It may not be designed for that, but it looks like it is up & running now. The annoying thing is that I'm not exactly sure how! Since it last didn't work, I've done the following:
1. Installed OpenFOAM, although I am convinced this has nothing to do with it, the info is just for completeness. 2. Used the Synaptic package manager and installed a bunch of stuff, including the sshd service and everything that looked like a glibc or libc package, including the 32-bit libs. 3. Configured passwordless ssh on the system. Anyway, it works. My guess is that step 2) is what made the difference. |
March 19, 2008, 13:24 |
I successfully installed Fluent 6.3 on UBUNTU 7.10 X86_64 "Gutsy". The only problem was that to run Gambit you need to install Libmotif. You have to search the package with Synaptics. Maybe in some systems you have this problem with Fluent, too. I can recall that to run Fluent on Opensuse 10.2 I needed to install Openmotif, the rpm equivalent to Libmotif.
Running Fluent, the only problem is that sometimes, when you click a button, you can't sellect an option with the mouse. You must use the keybord arrow keys to scroll through options. But turning off the compiz visual effects solved this problem. |
March 31, 2008, 13:56 |
Fábio, what did do to make fluent run properly on ubuntu 7.10? I'm having some problems: if I try to run as a user, it throws an error related to 'domainname' param. I can't run using sudo because hasn't set the environment variables. I found something on the internet about changing the script (sh to bash) to run on ubuntu. I have less error messages now, but sill can't make it to run. Can you help, please? Thanks in advance.
April 1, 2008, 00:13 |
Guys, finally made it. The deal is install package libmotif-dev and libstdc++5 using synaptic. Thus edit the scripts (e.g. .../Fluent.Inc/bin/fluent and ...Fluent.Inc/bin/gambit) changing the first line. Original first line: #!/bin/sh New first line: #!/bin/bash Now I have Fluent 6.3 and Gambit 2.4.6 fully functional on Ubuntu 7.10.
Hope it help you too, guys. |
Parallel Fluent on Ubuntu 7.10 | fluentos | FLUENT | 3 | January 25, 2013 07:23 |
linux-ubuntu & fluent | tamjid | FLUENT | 5 | February 16, 2010 13:44 |
Ubuntu 7.10 and Fluent | Gibbon | FLUENT | 1 | November 13, 2007 02:08 |
Fluent 6.3 on Ubuntu - doesn't work | adas | Siemens | 3 | March 24, 2007 02:03 |
Fluent 6.3 on Ubuntu 7.04 | adas | FLUENT | 1 | March 20, 2007 19:31 |
