April 4, 2008, 10:52 |
Help: mesh conversion from Gambit to ICEM
Dear all,
I have a mesh file (.msh/.cas, dat)generated from Gambit and I'd like to import it into ICEM-cfd. Although I can get the mesh in ICEM, but I don't know how to generate the geometry needed by ICEM. I need to modify the geometry in ICEM. Any help is greatly appreciated. Best, sarah |
April 4, 2008, 16:08 |
Re: Help: mesh conversion from Gambit to ICEM
You could try to covert the mesh to faceted geometry data: Edit-Menue: Mesh -> Facets. Afterwards try to build a diagnostic topology. You should be able to edit the geometry now. But this doesn't work everytime as expected... You want to check your geometry-tolerance in the Settings-Model menu. Good luck!
April 5, 2008, 01:53 |
Thanks a lot! I will try! *NM*
[Commercial meshers] Problem with Mesh conversion Gambit msh Foam | Rachid BANNARI (Bannari) | OpenFOAM Meshing & Mesh Conversion | 25 | September 11, 2011 07:58 |
Gambit mesh file import into ICEM CFD | dev.... | FLUENT | 2 | January 29, 2009 10:37 |
importing Icem mesh into Gambit | srinivas | FLUENT | 4 | December 12, 2008 04:06 |
ANSYS ICEM CFD Mesh to Gambit | Simon Bergström | FLUENT | 0 | January 19, 2007 11:53 |
gambit icem conversion | Tomasz Ochrymiuk | FLUENT | 2 | March 14, 2000 03:02 |
