April 7, 2008, 06:35 |
Error: > (greater-than) invalid argument
Hi people,
I got something concerning this error message: Error: > (greater-than) invalid argument (wrong type): not a number. Error Object nan There has been a lot of discussion around this error message. Even in the FLUENT FAQ there is a subject over this. But the solution I found was not in the answers provided. Also in my cases the error message came out of the blue. But the answer to resolve this problems was just changing the compiler. After compiling in fluent with cc, I changed the makefile in the /libudf/src/ to icc. Afterwards cleaned in the /libudf folder and make again. Loading the library and running again made the error message disappear. Hopefully this will help people in the futher. Kind Regards, Peter |
April 11, 2008, 14:51 |
Re: Error: > (greater-than) invalid argument
The answer for you specific case is given above, but in "case" you didn't know, "Error: > (greater-than) invalid argument (wrong type): not a number. Error Object nan" is a general error message that can arise due to many different reasons that will not be resolved using your "technique"
Thanks |
April 11, 2008, 14:59 |
"EPW"
Thanks for your "reply". But the "case" is that this error message "DID" resolve using an different compiler. Not saying that its "the" solution. But it is perhaps a good thing to "try" if you cant figure it "out" "thanks" |
April 11, 2008, 19:12 |
"your welcome"
Error: invalid argument [1]: improper list | Ralf Schmidt | FLUENT | 7 | May 29, 2017 05:26 |
ERROR - invalid argument / not a number | spepsicho | FLUENT | 7 | October 29, 2011 16:11 |
greater-than- invalid argument 2- nan - UDS | Ali | FLUENT | 0 | May 8, 2008 12:49 |
error with turbulence: invalid argument [1] | Ralf Schmidt | FLUENT | 0 | April 5, 2007 14:03 |
Error: GENERAL-CAR-CDR: invalid argument | Annie | FLUENT | 3 | September 12, 2003 03:15 |
