fluent error message
Old   April 23, 2008, 23:42
Default fluent error message
corey
Hi, just a quick question about an error message i am getting in fluent..
i have imported a gambit model into fluent, and after setting boundary conditions etc. i get the following error message when i try to begin iterating a solution:
Error: 1000000: Failed to allocate 52.43 MB Memory (...\...\src\amgif.c:1048)
Error Object: ()
Does this mean that the computer i am running this simulation on does not have enough memory for the simulation i am trying to run? Also, what would be the best way to get around this, as i dont really have any other option for computers.
Would a coarser gambit meshed model help? or can i change any settings in fluent?
thanks.appreciate the help.
regards corey.
Old   April 24, 2008, 16:19
Default Re: fluent error message
Ralf Schmidt
yes, a coarser mesh would help. In Fluent, you also could coarsen the mesh. Go to "adapt". Take care, that only the "coarsening" option is applied and "refinement" is disabled.
There are a number of possibilities, to coarsen the mesh - depending on the situation, you may coarsen it according to the distance from the wall, a certain iso-value,...
Best wishes Ralf
Fluent Error message Steve FLUENT 1 December 12, 2007 13:12
Fluent Error Message Jack FLUENT 1 January 19, 2007 10:50
Error message in Fluent Taher FLUENT 0 December 16, 2002 15:25
about error message in fluent Devy FLUENT 3 August 1, 2001 05:10
about error message in fluent Liews FLUENT 1 June 10, 2001 21:13
