Rotating a geometry in GAMBIT
Old   May 5, 2008, 02:38
Default Rotating a geometry in GAMBIT
Jake
Hi there, I am having trouble getting one of my geometry transformed to another location.
I have been using Align option to move one piece of geometry from on vertex to another vertex.
Now I have to actually rotate an edge while having one end fixed to a vertex.
The edge I am trying to rotate was created by someone else and has a wierd shape, that I cannot recreate it. Maybe the previous person created it with sweep or combination of vertices and some arcs. Anyway, unless there's a way to figure this out, I mean figure the way that previous person used to create the edge by going through GAMBIT menu, I will have to rotate it.
As I have said, one end needs to be fixed at that vertex. Then I only like to have the edge rotated toward inside direction so that part of it will interesect with other edge, because if I rotate it inward while one end fixed, I am pretty sure the other end would not meet with the desired vertex.
The problem is, even with align menu and rotation submenu, it just doesn't work. what do I need to do in Align menu? Help me out please
Gambit geometry creation: loading data to gambit C Ariyaratne FLUENT 10 March 17, 2011 16:39
how can i make rotating cylinder in gambit& fluent mohamed FLUENT 1 April 1, 2008 03:28
3D geometry in gambit Meenu FLUENT 7 May 10, 2007 15:51
geometry in gambit soundar FLUENT 4 December 28, 2004 04:29
Boundries of rotating impeller created in Gambit ? Mounir FLUENT 2 October 23, 2000 06:56
