Eulerian-eulerian multiphase modeling
Old   April 28, 2008, 22:39
Default Eulerian-eulerian multiphase modeling
Wee
I am using Eulerian-eulerian multiphase model to model the gas-solid fluidized bed. My study requires the bubble diameter in the bed. May i know how can i generate the results for bubble diameter by using the existing multiphase model?
Thanks Regards, Wee
Old   May 1, 2008, 04:37
Default Re: Eulerian-eulerian multiphase modeling
Roghayyeh Motallebzadeh
you can go to flent help in lagrangian eulerian section. I NEED A CODE TO EULARIAN -EULERIAN HEAT TRANSFER MODELING DO YOU HELP ME?
WITH BEST REGARDS
ROGHAYYEH
Old   May 5, 2008, 02:55
Wee
U can refer the tutorial in fluent, Tut 22: Using the Eulerian Granular Multiphase Model with Heat Transfer.
Old   May 14, 2008, 02:12
Ant
Wee,
Bubble diameter is a input parameter to the multiphase model. So you would need to either derive the average bubble diameter using some co-relation or use the Musig model to generate bubble size distribution in the model.
I would suggest the first approach since the flow pattern would be more important than the bubble size distribution. Also with all the complexities of Musig model you would never be sure if you model parameters are correct and it may give just an incremental difference in the results.
Regards, Ananth
Multiphase flow (Eulerian) modeling Umesh FLUENT 5 December 29, 2014 10:06
Singularity in two fluid model (Eulerian-Eulerian) Zak Main CFD Forum 4 February 28, 2010 17:54
Multiphase Eulerian & UDF HP FLUENT 0 August 24, 2006 11:58
Eulerian Multiphase Sam Siemens 1 July 21, 2006 15:12
enabling UDS in Eulerian-eulerian multiphase model shao1 FLUENT 0 July 14, 2002 22:23
