velocity update
Old   July 7, 2008, 08:15
Default velocity update
fluent_urs
dear all,
if i want to update the particle velocity after every time, how do I do it ?
hoping for a reply.
best regards.
Old   July 7, 2008, 08:30
Default Re: velocity update
hbinma
Maybe you should use "UDF"(User-defined) regards
Old   July 7, 2008, 09:04
fluent_urs
hi, thank you for your reply. yes, i understand that i need to use UDF. but can you show me with an expample. regards.
Old   July 8, 2008, 01:29
hbinma
There is a UDF Manual in FLUENT Documentation. If you do not have it, you can find it in this link: http://www.engres.odu.edu/Applicatio...df/udf/pdf.htm
I hope it can help you.
Old   July 8, 2008, 02:34
fluent_urs
dear sir,
thank you very much. I downloaded it. Ccan you tell me which UDf example are you referring at ?
thanks and regards.
Old   July 8, 2008, 10:52
hbinma
There is a FLUENT 6.2 Tutorial Guide in this link: http://www.engres.odu.edu/Applicatio...g/main_pre.htm The 4th topic, Modeling Unsteady Compressible Flow ,involve something about using UDF. However,if you want to know that how to write UDF functions, you must read the whole FLUENT 6.3 UDF Manual.
Old   July 8, 2008, 11:41
rr123
thanks, i appreciate your help. but unforttunately you were not able to understand my query..
Any update on mixerGgiFvMesh jaswi OpenFOAM Running, Solving & CFD 69 April 20, 2013 12:22
Git Update Problem cwang5 OpenFOAM Installation 0 September 12, 2008 02:44
How to update volVectorField velocity swlee OpenFOAM Running, Solving & CFD 0 June 18, 2008 04:57
FLEXlm update or ?? Kasper Skriver Siemens 2 March 1, 2007 10:38
Update Fluxes luca OpenFOAM Running, Solving & CFD 2 March 29, 2006 10:47
