RE: Parallel job in Vista-32
Old   July 11, 2008, 02:39
Default RE: Parallel job in Vista-32
Kevin
I'm a relatively new user of FLUENT/CFD and am curious as to how to properly set up my single Q6600 machine to run parallel simulations. So far, I have yet to see any performance increases running through "Parallel FlUENT" and serial FlUENT. In addition, using the FLUENT launcher in parallel mode usurps 75% cpu without even having loaded any *.cas file.
Some questions: 1) Must I set up a host file? 2) In fluent launcher, since I'm using a 32-bit O/S, I only have access to the following MPI options (default, mpich2, net). Which should I be using? 3) Are parallel jobs dependent on having a proper license key?
Regards, Kevin
Old   July 11, 2008, 12:22
Default Re: RE: Parallel job in Vista-32
umesh javiya
Very easiest way to do it.....without knowing any thing.....
just right click on fluent shortcut and somewhere it says application location like as follow....
c:\Fluent.Inc\ntbin\fluent.exe
just change it to
c:\Fluent.Inc\ntbin\fluent.exe -t4
that is it....enjoy....
-t4 means four processors.
-t2 means two processors....
vista, cfx 11 alireza CFX 6 February 25, 2008 09:19
Vista & CFX 11 SP1 lefuture CFX 0 February 1, 2008 08:50
vista vs Ansys macdidi@caramail.com CFX 2 December 4, 2007 22:24
Support on Vista?? david FLUENT 7 September 12, 2007 23:37
EXCEED FOR VISTA shriram Main CFD Forum 6 July 27, 2007 12:47
