Air mixing, difficult question
Old   July 17, 2008, 12:29
Default Air mixing, difficult question
jeremy
Hello world,
I want to modelize mixing between two flows with a 2d model.
The first one is a high pressure flow (30 to 100 psi, ie 2e5 to 7e5 Pa, positive x direction) The other one is low pressure flow (ambiant pressure, positive y or x direction, it depends mesh choice).
I tried to use different viscosity models ( the best one seems to be RNG k-epsilon). Segregated or Coupled solver, the coupled seems to be the best even if convergence is hard (oblige to turn off equations, decrease numbers,...).
But, I have a big problem, when i use : Display > path line i have not mixing between two flows. They are still segregated.
I tried to use define > model > multiphase > mixture with regular settings but i have still same results.
Have you an idea ?
Everything happens as one flow can't penetrate the other one. The high pressure jet can drag along the low pressure gas but nothing else.
Have you an idea ?
Old   July 18, 2008, 00:40
Default Re: Air mixing, difficult question
ravi kumar
try to use species transport model.. then u can see the mixing of the two gases in the contours of mass fraction.. hope this may be useful...
Old   July 19, 2008, 17:34
jeremy
Thank you for your help
I fallowed your advice. But, because both of jets are air, the mass fraction is constant (=1) everywhere. Other Idea ? I will try to change one air stream for a benzene stream and check if the mixing happens. I don't need to take values on it but i want to be sure it occurs.
Best regards.
Old   July 20, 2008, 10:30
Prakash
i hope there will not be any mixing. its natural that high pr fluid will tend to drag the low pr fluid.isn't it?
See Fluent tutorial no.1. I think it is same as ur problem.
Difficult ICEMCFD question: Extrusion Walter CFX 11 April 19, 2011 02:22
Whose programming is more difficult?DNS or LES? Adonis Main CFD Forum 5 January 6, 2006 16:23
cfx is Difficult to learn? SAM CFX 3 October 31, 2004 17:05
convergence difficult Jason FLUENT 3 May 20, 2004 12:13
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 07:39
